This piece has very low volume. Took it apart and measured voltages off tubes. Pin1 -5.87, pin2 -11.16, pin3 -11.42, pin6 0, pin7 -10.39, pin8 -10.64. Now I know these are very low, and according to schematic I should have around 170v. Where should I begin looking in the power supply for trouble. Thank you in advance for your help. Danny
Ada Microtube200 PA troubles
Those transistors are just voltage regulator pass transistors. Are all of the other voltages ok? The 75 and the -12?
The 170 volt supply is turned on and off via the standby switch. Have you checked the switch? Are there 220 volts on the switch terminals?
Heres something that just happened. I was trying to measure the voltage on the base of Q10 and accidently shorted the base and emitter together, i got my volume back. Voltages for Q10 are Emitter 236.5v, Base -318.6mV, Collector -0.876V. Im thinking replace Q10. Does that sound right. Thanks Danny
Somebody must have worked on this thing before I got it because Q8 was installed backwards. According to the PSU Loading diagram the way they had it installed was correct. But according to the schematic it was incorrect. So anyway pulled it out installed a new one and I have volume now. Thanks for the reply Danny
