Results 1 to 8 of 8
Thread: First time post, first time building cabinets
    Feb 2008
    Lee's Summit, Missouri
    36
    0
    Thumbs up First time post, first time building cabinets
    Howdy all, I've been lurking here for a little bit and like what I see. Good advice all around. Love to share my first attempts at making some extension cabinets after almost dying of sticker shock for a 2X12 Mesa cab to go with my Rect-o-verb.
    The first picture shows my first attempt at box/finger joints. Pretty rough as my partner didn't take much time in making the cuts. But it holds....so far.
    Second is attempt number 2, which worked much better...except that in picture 3, you can see it's not a box, it's a parallellagram (sp?) DAMN!
    Last pic is my first cab loaded with some cheapo 12s, while it awaits a new load of 1 Celestion V30 and one G12H-30 and some grill cloth that are sitting on the workbench.
    So, I think I'm on the right track...next cabinet gets built from pine or some other wood.
ID:	1867   Click image for larger version.
ID:	1868   Click image for larger version.
ID:	1869   Click image for larger version.
    Pickup Maker David Schwab's Avatar
    Staten Island, NY
    10,951
    Received: 12/0
    Given: 6/0
    27
    Quote Originally Posted by csparks75 View Post
    Looks good. They just need some sanding. Get s random orbit sander and sand them flush and smooth. Everything made from wood needs sanding.
    Did you ever watch New Yankee Workshop? Norm's always showing the standard way you take care of that. You diagonally measure from one corner to the opposite corner, and then repeat that for the other two. Then make them match!
    Looks like a great start. I've been meaning to make myself a 2 X 12 bass cab.
    It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. Albert Einstein
    Feb 2008
    36
    0
    I love new yankee workshop! I want to hear Norm say: "Always wear your safety glasses, because my tools are so bad-ass and I'll make it look so easy that you need something to keep the eyes inside your head" LOL
    Yeah, thought I did that but I have had problems in the past with a measuring tape. I still have a ways to go, like applying a finish, adding handles, feet, etc. to the first one. I think when it gets warmer, I may have to rip the new one apart and start over. It's driving me crazy.
    Thanks!
    Jun 2006
    439
    14
    It's not easy to measure the inside diagonal of a box with a measuring tape.
    One trick is to use two sticks, each of which has one end cut to a bit of a
    point so it'll reach into a corner. You hold... oh wait a second, a picture will
    be a lot easier than trying to explain with words...
    Here :
    So you jam them into the corners and hold them together while you check
    them against the other diagonal. You don't care what the length is, just
    that the two diagonals be equal.
    If you have a long bar clamp you can put it across the longest diagonal
    and squeeze those corners together until the box is square.
    I'd still use a builder's square on the inside for good measure.
    Paul P
    Jul 2017
    British Columbia
    357
    Received: 5/0
    3
    Quote Originally Posted by David Schwab View Post
    There are multiple types of right-angle clamps that make this job much simpler, and much less error-prone.
    Here are a few:
    1) https://www.homedepot.com/p/BESSEY-9...3-2K/204958410
    2) Right-Angle Assembly Clamps - Lee Valley Tools
    3) https://www.amazon.ca/Wolfcraft-3415.../dp/B000JCGYD6
    4) https://www.amazon.com/gp/product/B0...pf_rd_i=553152
    IMO, in this era of excellent wood glues, and easy and extremely strong biscuit-joinery, dovetail joints are about nostalgia, not function.
    -Gnobuddy
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    15,897
    Received: 2,744/4
    Given: 3,208/0
    30
    ...it awaits a new load of 1 Celestion V30 and one G12H-30 and some grill cloth...
    I don't know if you've used that speaker combo before, and that's why you chose them, but I love my 2x12 with a V30 and a G12H30
    Supporting Member
    Apr 2007
    1,071
    Received: 65/0
    Given: 45/0
    14
    I'm just glad that I didn't take pics of my first few cabinets!
    They held the speakers OK, but sure weren't much for looks!
    May 2007
    pacific north west
    15,897
    Received: 2,744/4
    Given: 3,208/0
    30
    Same here.
  1. First time building Craig Anderton Tube sound fuzz... need help!
    By acobberson in forum Music Electronics
    Last Post: 02-22-2008, 06:19 PM
  2. First-Time Post / Bass Amp Questions
    By Joe Viau in forum Other Amps
    Last Post: 12-09-2007, 02:08 PM
