9VAC powered LED?
  • 9VAC powered LED?
    I would like to use this device on a pedalboard powered by a Pedal Power AC power supply.
    http://fulltone.com/PDfFiles/AB_switcher.pdf
    Can this unit be modified for use with AC?
    Bret
    Yes, it most definitely can. Quite possibly with 1 diode, 1 resistor and 1 cap.
    Last edited by Liam; 02-24-2008, 12:17 AM. Reason: keyboard operating inadequacies
      Hello and thank you so much for your kind reply.
      If you please, would you also kindly provide a schematic for such a modification?
      Thanks in advance,
      Bret
        Unfortunately not, haven't got any way of drawing or scanning one.
        RG wrote some nice stuff on power supplies a while back. The basic half wave rectifer (first diagram) should be OK for what you are doing:
        http://www.geofex.com/Article_Folder...s/powersup.htm
        This can be used as the diode power supply, shouldn't matter if it's a little noisy as the signal is separate from the diode circuit. The 9V AC goes in at the left, and slightly ripply 13 V DC will come out the other side.
        I would suggest a 1N4002 diode and a 100 uF 25 V electrolytic capacitor as a starting point. I would also suggest going up on the resistors on the LED legs to 12k or 15k.
        If the LEDs appear to flicker you might want to consider a bit more filtering, but the above should work.
        Liam
          Ok,
          I will give it a try and report what happens. If I mis-wire something, is there a significant risk of damaging the Pedal Power power supply?
          The IN4002 has two "leads" and the 7809 has three "leads." How do I wire the IN4002 in the shown schematic in the link?
          Sorry for the newbie questions.
          Bret
            What's a 7809?
              In the schematic located in the link you posted (geofex) there is a component labeled '7809' which I took to be a diode.
              It has three leads vs. two on the diode you recommended.
              Take a look at the link and you'll see.
              Sorry if I mis-interpreted it.
              Bret
                I was actually suggesting you use the first diagram for what you're making - just one diode and one capacitor. I think a regulated supply is overkill just to power 2 LEDs.
                Liam
                  Ah yes. I was looking at the wrong schematic.
                  Thanks so much for you assistance, Liam.
                  I think I am all set now.
                  Bret
