Hi all. Just finished a Smokin'Joe II from T. W.'s website. It sounds great except when the Master Volume pot is at either extreme turn. At "0" the amp squeals or hisses, and at "10" the amp motorboats. In between it sounds great. The tubes are good from a working 18 watter, and all passive components are new. Any ideas and help would be greatly appreciated.
Smokin' Joe II oscillation
If that design has a feedback from the output of the audio to
some where back to the splitter circuitry, temporary disconnect.
If those issues clear up.
Then your wires need to be exchanged on the windings of your output transformer's split windings. The feedback can be reconnected
Hi Tom. I swapped out shielded wire from power amp to MV pot, which cured the motorboating and noise at "0". I now only have a little screetching when pegged at the "10" position. The noise ends quickly as soon as I back off. Everywhere else the amp sounds great.
