PT values for 5E3, 5E9A and 5F11
  • PT values for 5E3, 5E9A and 5F11
    Hi there
    I am mulling over which one to build next.
    Since I am in the amp modding backwater of the planet I have to get the PTs and OTs made up especially.
    I was wondering if there was much difference in the PT volts/amps values for the above
    My guess is that the 5E3 is something like:
    320-0-320 1A (With a 5Y3GT, or is that too high?)
    5 - 5 2A
    6.3-0-6.3 3A
    (Hope I've got enough buffer in those current values)
    I can't see there would be any difference for the 5F11 (same number and type of valves)
    But does this change much if you go to a 5U4GA and add a 12AX7 (for 5E9A)?
    Cheers
    A 5u4 draws 3 amps from the 5volt winding, so a higher capacity transformer would be needed, to use that rectifier. 1000ma of B+ .... was that a typo?
    320-0-320 is fine. If you have the room on your chassis, the Vibrolux tranny is the ticket.
    TRANSFORMER, POWER, FENDER REPLACEMENT, 325-0-325 V, 180 mA
    P-TF22723
    Replacement for Fender Vibrolux. Equivalent to #125P26A & # 036483. 35 Watts.
    Primary: 117 volt, 60 Hz
    Secondary: 325-0-325 V, 365VDC@180 mA(DC) with 50 V bias tap
    Filament winding 1: 6.3 V, 4 A
    Rectifier Filament: 5 V, 3 A
    Mounting centers: 2.5" x 3.125"
    Weight: 6.5 lbs.
    Sometimes I'm good, then I'm bad..
    http://www.evacuatedelectronics.com
      Ooops,, didn't see the part about where you're from.. Sorry.. Anyway those specs I posted are good for the circuits you mentioned.
        P-TF22723
        Weight: 6.5 lbs.
        The amp he is talking about is a little thing making less then 10-12 watts.
        You are thinking brown or black face amps. Totally wrong transformer for his projects.
        Bruce
        Mission Amps
        Denver, CO. 80022
        www.missionamps.com
        303-955-2412
          True, it would be overkill for sure, but a 5u4 rectifier was mentioned. If that weren't the case then something like a deluxe trans. would do it.
