Peavey Heritage vtx
  • Peavey Heritage vtx
    This is my first tube amp and I've had 2 new 100 watt 8 ohm Jensens wired exactly like the original Scorpions were and a set of new Ruby tubes. Now I've recently got into a band and were probably gonna start gigging in a few months and I was wondering if I could run the 2 Jensens with an additional 4x12 cabinet. If so then what cabinet brand, omhs which I believe by the spec sheet from Peavey should be a 4 ohm cabinet, and any other info about a cabinet and options.
    Also if yes then would it give me enough power to play at mid size venues in front of a few hundred people without the amp being mic'ed.
    If no then what kind of amp head and cabinet would be best on a budget of around $800.
