Have a Mesa Nomad 55 combo in with low output and poor tone. Plugging signal into the fx return produces decent clean output, slave out, headphone out/recording out and fx out has no signal present (scoped at these points-nada). Opened amp and started checking voltages-tubes seem correct-found one of the opamps (5532) and checked supply voltages-pin 8 shows +15v dc but pin 4 shows -2.6v dc. Traced negative supply back to a 68R resistor and followed it back to the rectifier diodes (these apparently were replaced once in the amp's lifetime). Low voltage out from transformer looks okay and as mentioned am seeing 15v positive on pin 8. Lifted the end of the 68R (there are two in series-lifted the end furthest from the rectifier diodes and closest to the opamp) and got -30v dc-pin 8 voltage dropped to about +6volts dc or so-assume something is drawing the negative supply down-what should I look for next? I am relatively new at the 'game' here so if I am overlooking something very obvious to check next please go easy The layout of the board is a real PITA to get to the underside and since I have no schematic or board layout and the PC is double-sided I am totally lost. Any assistance (or a prod in the butt) to the next step would be greatly appreciated.
TIA-Craig
TIA-Craig
