Wiring a new guitar. It works fine with the input jack partially inserted, but nothing at all when pushed in all the way. I've changed jacks twice thinking the problem might be there, but it's the same thing all over again. Can anyone identify the problem? No doubt I blew it somewhere in the wiring. Thanks for any help!
Guitar Jack issue
SOunds mis-wired. You have ground and hot wires coming to the jack, right? Look closely at the jack. See how it is constructed. One springy contact will press against the tip of the plug, when the plug is inserted. Follow the metal of that contact and see which solder terminal it goes to. COnnect the hot wire to that. The sleeve or barrel of the plug fits through the metal bushing and makes contact there. See which terminal connects to that and connect the ground wire to it.
Other possibility? Maybe where the jack mounts, the tip contact is touching something grounded inside the guitar? If that might be it, demount the jack and let it hang by its wires outside the guitar. Now does it work right. If so, that was what was wrong. Remount the jack so as not to touch.Education is what you're left with after you have forgotten what you have learned.
Sounds like you are using a stereo jack (three lugs) and have the tip and ring mixed up.
Is it a panel (barrel) jack?It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by Enzo View PostSOunds mis-wired. You have ground and hot wires coming to the jack, right? Look closely at the jack. See how it is constructed. One springy contact will press against the tip of the plug, when the plug is inserted. Follow the metal of that contact and see which solder terminal it goes to. COnnect the hot wire to that. The sleeve or barrel of the plug fits through the metal bushing and makes contact there. See which terminal connects to that and connect the ground wire to it.
Originally posted by David Schwab View PostSounds like you are using a stereo jack (three lugs) and have the tip and ring mixed up.
Originally posted by ericjay View PostYes, there are 3 lugs(flush mount long barrel). Will rewire in the morning. Sounds like you're right on. Thanks for your analysis.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
