Just built another 5e3 with all the best goodies. The problem is a low frequency hum that never goes away. I think I've isolated it to before the .1 mfd caps going into the vol. pots by shorting the cold side of the cap. When I do that the hum stops. I've changed the caps checked everything like solderjoints, changed tubes etc. Also if I crank it up it sometimes it starts to make this plop plop plop noise. Any ideas?
5e3 hum problem
Originally posted by tubelovin View PostJust built another 5e3 with all the best goodies. The problem is a low frequency hum that never goes away. I think I've isolated it to before the .1 mfd caps going into the vol. pots by shorting the cold side of the cap. When I do that the hum stops. I've changed the caps checked everything like solderjoints, changed tubes etc. Also if I crank it up it sometimes it starts to make this plop plop plop noise. Any ideas?
BDMy Kansas Cover Project...
http://www.soundclick.com/bands/4/bd...ends_music.htm
My Original Tunes...
http://www.soundclick.com/bands/8/billdurham_music.htm
Here is one tip. Determine if the hum is 60Hz or 120Hz. They sound really similar. 120Hz is power supply ripple from wherever. 60Hz hum comes from radiated fields or other mains related sources.Education is what you're left with after you have forgotten what you have learned.
hum
Just re-read your original post.. does it go up and down with the volume controls? Also does it go away when you plug in a guitar?
just trying to help
Yes it does get louder when I turn up the volume and no there isn't any change when I plug in my guitar. That tells me that it's in the pre stage. I don't have a lot of experienve, so it could be something simple. Is it possible that it's a ground loop? How would I diagnose?
Originally posted by tubelovin View PostYes it does get louder when I turn up the volume and no there isn't any change when I plug in my guitar. That tells me that it's in the pre stage. I don't have a lot of experienve, so it could be something simple. Is it possible that it's a ground loop? How would I diagnose?
I just took a look at the schematic for the 5E3. I would suggest that you float the input jacks above chassis ground and also connect the ground side of the 1 meg resistors back to where the cathode bypass cap and resistor are grounded.
this might help
I was actually using the ground teminal of the input jack as the ground for the cathodes and pots. I was thinking of getting those plastic washers to isolate the jacks from the chassis, just haven't ordered those yet. Whats your opinion on grounding pots to there case. I read that it can contribute to ground loops, but I see many people doing it.
Originally posted by tubelovin View PostI was actually using the ground teminal of the input jack as the ground for the cathodes and pots. I was thinking of getting those plastic washers to isolate the jacks from the chassis, just haven't ordered those yet. Whats your opinion on grounding pots to there case. I read that it can contribute to ground loops, but I see many people doing it.
The ground buss in a pcb, non-mv Marshall IS the buss wire that is run between the cases of all of the pots on the front panel. Everything from the board ties to that point. Since that is the point that was chosen in that case, I think it works good for them, but if you are thinking about doing it in addition to what you have done already, I don't think it probably make things worse before making them better. You need to have a plan for your grounding scheme and most folks agree that you should have one and only one connection to the chassis. If you connect to the chassis in multiple places, eddy currents can develop between those connections through the chassis. Net result is hum and or noise. I'm not saying that is your problem now, but it could be if you have multiple connections of your ground buss to the chassis..as in the input jacks, the output jacks, a wire from the board ground point to the chassis, the center tap of the PT high voltage winding....etc.My Kansas Cover Project...
Just changed the 22K resistor in the B+ string and the hum went away.....sort of. It was a metal oxide now it's carbon film.
Now I'm getting grid hum on V2. It's the lone one from the control to pin #2. I noticed that when I touched the amp the hum went away. Then I figured I would tape some aluminum foil to the back panel as a shield and the hum is almost gone to the point where you have to have your ear to the speaker to hear it at all.
Why would one 5E3 that I built be so quiet and the other so noisy? The build is exactly the same, but this one hisses and hums.
