Anyone know the value of R58? Any links to the schematic? Thanks!
Marshall AVT50 - burned R58
10 ohms. It is part of the stability network. If it burned up, the power amp was putting out tons of high freqs that didn't belong there.Education is what you're left with after you have forgotten what you have learned.
Actually it doesn't have a lot to say about the chip either way. Just plug the input into the output, and that resistor will likely burn, while the chip may well survive. On the other hand, sometimes the process takes the chip with it.Education is what you're left with after you have forgotten what you have learned.
One year later and I had the exact, same question. Three cheers for the Search Bar!!! And a couple of cheers for Enzo.
Thank You
