Results 1 to 3 of 3
Thread: Peavey Bandit Reverb Issue
    New Member
    Jan 2007
    4
    0
    I have a Peavey Bandit that has a peculiar problem. Sometimes, when I turn it on, the reverb circuit doesn't engage. If I turn it off and on, it usually comes back and everything is fine until the next time. It doesn't happen all the time, either.
    Any ideas ?. Could it be the on/off switch itself ?. Could it be the reverb board / circuit ?.
    I'd like to have a clue before sending it in for repair.
    Old Timer
    Jun 2007
    5,129
    Received: 108/0
    Given: 66/0
    19
    Quote Originally Posted by fxcarden View Post
    It would be unusual for the circuit to electronically lock up, but not imposible.
    More likely, the problem is mechanical in nature. Check to see that the Molex plug that connects the tank and the chassis is making good contact, check the tank connections where the wires plug into the tank, and check the tank coil wires that connect the small transducer coils to the RCA jacks inside the tank itself. Any problems with these wires will cause the symptoms that you describe.
    Additionally, there may be something loose on the circuit board in the reverb section. If you feel able, pull the chassis out of the amp and look for loose components on the board. The reverb tank wires will lead you to the area of the board that contains the reverb circuitry. Also. check the area around the reverb control for cold or broken solder connections.
    Hope this helps.
    New Member
    Jan 2007
    4
    0
  1. Peavey 5150- low volume issue
    By pattonface in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-09-2007, 09:13 PM
  2. Acoustic 470 reverb issue
    By gbono in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-27-2007, 03:54 AM
  3. Peavey 5150 combor reverb pot
    By Gregg in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-26-2007, 11:40 AM
  4. bandit 112 problem
    By JC@ in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-04-2007, 08:32 PM
  5. correct speaker for a Bandit
    Last Post: 12-19-2006, 12:23 PM
