Made from a Grizzley lathe
picture of my winder
Very cool, Mystic! I'm still using a sewing machine motor. This may be my next investment. Where did you get the traverse end-stops?
i've looked everywhere and can't find them. I actually use rubber grommets ;-)
Originally posted by Stan HVery cool, Mystic! I'm still using a sewing machine motor. This may be my next investment. Where did you get the traverse end-stops?
1. Added a reverse switch to the motor (works well but I havent used it yet)
2. Added a counter (red lion counter + prox switch trigger)
3. Added the traverse stops (and shaft)
4. replaced the metel bed tubes with shorter plastic ones.
5. made a face plate out of plastic.
6. added a tention clamp and hand rest. (not pictured)
The counter cost more than the lathe.
Here'a a link to the lathe. http://www.grizzly.com/products/G8690 $143 0 to 3000 r.p.m. The harbour freight lathe isn't variable speed.
Great winder! I was tempted to build one of these. I might still at some point. Looks sturdier than my Schatten winder!
[edit: I added a picture of my winder... just in case no one knows what they look like!]
Last edited by David Schwab; 05-12-2006, 05:44 PM.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
How did you do that?
How did you include your photo in the email? When I try, I get HTML code instead.
Thank you,
Ken
Originally posted by MysticThe traverse stops are just collers I got at the hardware store. The only modifications I made were:
