I finally obtained the resistor I was needing to fix my Ashdown Peacemaker 60, but somebody had already " worked " on it before I bought it. Whoever worked on it before butchered the trace on it completely. I don't know if there is anyway to fix this or what since my amp is out of production. The trace itself is destroyed for the one resistor the rest of it is fine. If there are any suggestions I'd greatly appreciate it.
Circuit Board issue!!!!!
It's not that hard ... it seems formidable, but it is doable.
I know because I did it yesterday.
The two methods are:
- scrape one end of the trace and solder to it (either a wire or the resistor lead)
- solder a wire to replace the traceSee the birth of a 2-watt tube guitar amp - the "Dyno Tweed"
