5E3 chassis Q
  • 5E3 chassis Q
    Hi there, can anyone remind me of these measurements on a std repro 5E3 chassis:
    1. the distance between the 2 mounting bolts, and
    2. the distance this hole sits in the std 5e3 cab, ie between cabs top back & the cutout area. Or from a std 5e3 top front may be easier to ask like so.
    I just cant find these dimensions on the www. Thanks all
    The 2 mounting bolt holes are 13 1/2 " on center. And 1" in from the inside face of the back panel. The hole is slotted in this direction, so you have a little wiggle room front to back. (This is a Weber chassis.)
      Thanks alot for info Daveg, rgds Capt.
