Results 1 to 10 of 10
Thread: Aluminum corrosion cleaner
    Supporting Member Axtman's Avatar
    Feb 2007
    Seattle WA
    434
    Received: 42/0
    Given: 2/0
    13
    A friend gave me his 1967 black face Fender Vibrolux to repair. The first thing I have noticed is the aluminum corrosion on the chassis and tube shields. It is like someone sprinkled baby powder all over it. There is a thin film of white powder. How to I clean this corrosion?
    Supporting Member tubeswell's Avatar
    Feb 2007
    Wellington NZ
    4,202
    Blog Entries
    1
    Received: 133/0
    Given: 45/0
    18
    Maybe try various light cleaners on it first
    like meths rubbed on with a clean rag.
    Or vinegar or (real) lemon juice
    You will need to clean the this stuff off afterwards
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,439
    Received: 2,003/7
    55
    Touch a magnet to that chassis. I don't think it is aluminum. A lot of old Fender amps have a breakdown on the metal surface. I THINK it is zinc oxide or something, because I think there is a galvanized finish on it, or was. MAybe? Someone? I brush it off, and for the most part leave it. But that's just me.
    If I needed to clean an aluminum surface, I'd look two places - household cleaners and automotive cleaners. They make cleaners for aluminum cookware, and the auto industry has cleaners for aluminum wheels. ANd the hardware store probably has general purpose amuminum cleaner, I'd bet.
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Received: 13/0
    23
    Be careful with aluminium wheel cleaners, some of them contain some really nasty chemicals, hydrofluoric acid and ammonium bifluoride.
    http://www.kidsource.com/kidsource/c...er.danger.html
    32,439
    Received: 2,003/7
    55
    Oops.
    Senior Member capnjuan's Avatar
    Apr 2007
    120
    13
    Quote Originally Posted by Axtman View Post
    .... The first thing I have noticed is the aluminum corrosion on the chassis and tube shields.
    Try Flitz Metal Polish; http://www.flitz.com/index.html perfect for tube shields, control panels, and chassis surfaces. John
    Aug 2008
    23
    0
    Thumbs up Aluminum cleaner on my tube shields
    I just cleaned the aluminum tube shields on my 60's Gretsch amp. I noticed the exact same powdery coating. I used two rags. Put the polish on one and rub the finish. Then quickly wiping off excess with another and buff. You get a lot of black crap that comes off on the rag. Try and rotate the rag to keep that stuff from redepositing on the clean metal before it dries. Mine now look brand new!
    Old Timer defaced's Avatar
    Dec 2006
    York Pa
    1,394
    15
    Stainless steel wire brush or emery cloth would be my first choices. You can pickup the wire brushes at Lowe's in the welding department, they look like tooth brushes.
    -Mike
    Apr 2007
    120
    13
    Quote Originally Posted by Mutato View Post
    Hi Mutato; the chemicals in the cleaner turn the corrosion black. If they are covered in 'bumps' and you've cleaned them as far as you can go, then only resort to emery cloth; it's gonna scratch so if you want a highly polished finished, you're going to have to use #1200 and #1400 and so on before you get a shine. John
    Aug 2008
    23
    0
    Mine came out great. Just had a fine powdery finish. No pitting. Not sure what the original poster did, though.
  1. Getting a cleaner, louder Blues Junior
    By papuanewjimmy in forum Mods & Tweaks
    Last Post: 11-02-2009, 07:53 PM
  2. Corrosion on circuit board
    By Neal in forum Music Electronics
    Last Post: 03-31-2008, 03:53 PM
  3. spray cleaner?
    By mike_mccue in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-17-2007, 10:02 PM
  4. Just Curious - Aluminum or Steel
    By Jag in forum Theory & Design
    Last Post: 06-10-2007, 08:59 AM
  5. Aluminum Rack Chassis Supplier
    By tbryanh in forum Cabinetry
    Last Post: 04-24-2007, 03:20 AM
