Feedback loop
  • Feedback loop
    Hey 5e3 builders
    I was trying with a feedback loop on my 5e3 deuxe like fender did on the 6g2 model. But it does not work, it squiiiils like he.. when I connect the 56k resistor from the catode on the 2 gain state to the output.
    Why is that.
    Glasstone
    It appears that your feedback is positive. To make it negative just reverse your OT secondary leads OR reverse the OT primary leads. Whichever is easier. Then try hooking up the feedback loop again.
    Good Luck,
    Tom
      Out of phase is right, reverse the two leads on lugs 3 of the power tubes.... but if you try to connect this 56K NFB lead to the cathode of the first 12AX7 triode, the NFB will not work.
      The cap will bypass most of it to ground.
      Bruce
      Bruce
      Mission Amps
      Denver, CO. 80022
      www.missionamps.com
      303-955-2412
