Any amp similar to GA-5
  • Any amp similar to GA-5
    I played a vintage Ga-5 with the 6v6's, not the newer ones with the El-34. I really liked. Is there an amp kit or (amp I could mod) that will deliver that GA-5 tone with a 6v6? I need a straight forward solution since I've never built an amp before but am ready to....
    Thanks,
    Rick
    Here is one schematic:
    http://www.freeinfosociety.com/elect.../gibsonga5.pdf
    one 12AX7, a 6V6 and a 5Y3 rectifier.
    It is pretty close to the Fender 5F1 Champ with some minor parts value changes.
    This page says one of the early versions of the GA-5 was similar to Fender's 5C1 Tweed Champ:
    http://www.drtube.com/guitamp.htm
    The links don't work though
    Try these:
    http://www.ampwares.com/ffg/schem/champ_5c1_schem.gif
    http://www.ampwares.com/ffg/schem/champ_5c1_layout.gif
    Which one of these was closer to the Gibson GA-5 you played?
    Either one should be fairly simple build for a beginner.
    chuck
    Thanks,
    Rick
