This was quite a surprise to me: I went to my local ace hardware and bought some stainless steel button head screws for a high output pu I wanted to try. I realized tht they were probably hardened so I got out my torch and some ceramic blanket to anneal the screws, as well as a magnet to test for non magnetic. I tried the magnet on the screws before heating them up and I kid you not, they were non magnetic. The magnet I was using is a rare earth beast from a hard drive that will attract and hold anything with any iron in it (it will pick up chain from an inch away). The "Steel" screws that you can get from a hardware store aren't always very "steely" or ferrous, so test them before using. Maybe that's my new marketing scam "Non magnetic polepieces for quieter operation..."
Warning regarding screws
Tags: None
Originally posted by ShannonH View PostThis was quite a surprise to me: I went to my local ace hardware and bought some stainless steel button head screws for a high output pu I wanted to try. I realized tht they were probably hardened so I got out my torch and some ceramic blanket to anneal the screws, as well as a magnet to test for non magnetic. I tried the magnet on the screws before heating them up and I kid you not, they were non magnetic. The magnet I was using is a rare earth beast from a hard drive that will attract and hold anything with any iron in it (it will pick up chain from an inch away). The "Steel" screws that you can get from a hardware store aren't always very "steely" or ferrous, so test them before using. Maybe that's my new marketing scam "Non magnetic polepieces for quieter operation..."
Austenitic Grades of stainless steel (e.g., 18/10) have very low magnetic permeabilities and hence show almost no response to a magnet when in the annealed condition; however some steels in this category will show quite a strong response to a magnet, after substantial cold working e.g., Grade 304.
Originally posted by dwhutchens View PostI'm thinking its normal for stainless steel to be non-magnetic.
Used to work quite a bit with stailess steel. I even used to know how to TIG-weld stailess...long time ago.
I'm used to working with
440C, so it was a surprise to me. 440C is magntic, but too hard for polepieces.
Fundamentally, there are three "kinds" of stainless steels: austenitic, ferritic, and martensitic, which each have a primary phase of austenitic, ferrite (which is what makes steel magnetic), and martensite. The microstructure is primarily determined by their composition. Of their composition, chrome and nickel are the two main ones that make a stainless steel "stainless". The 18-8 stainlesses (304 is the most common of them) that have been discussed in this thread are 18 wt% Cr and 8 wt% Ni. 440C is a ferritic stainless which has 18 wt% Cr and no nickel. 410 is a martensitic stainless which has 12.5 wt% Cr and 0.75 wt% Ni.
The stainless typically used for screws is 305, which is 17-19 wt% Cr and 10-13 wt% Ni. It's used for this because it has the lowest work and strain hardening rate of all the austenitic stainless steels.
because they have not used enough chrome and nickle
Article specifically about stainless steels and magnetism: http://www.mceproducts.com/knowledge...-dtl.asp?id=18Last edited by defaced; 05-10-2008, 05:37 PM.-Mike
