I am doing a lot of testing these days and i think i fried my volume pot with all the repetitive heating with the iron. What are the signs of a burned out volume pot. I'm getting thin and shrill tone from one of my guitars.
Signs of a fried volume/tone pot?
Tags: None
do you have to unsolder the leads to get a reading?http://www.SDpickups.com
Stephens Design Pickups
Originally posted by GlennW View PostIf you're unsoldering and resoldering a lot you might want to leave a couple wires 2"-3" long on the pot and use wire nuts or just twist the wires for testing. It's a lot easier and quicker, and won't cook your stuff.
I bought some NOS Centralab pots for my LP's but they don't have splines on them any idea how to use typical gibson knobs on these? They're supposed to the stuff to use for original burst tones, I have NOS bumble bee caps in the Epiphone....http://www.SDpickups.com
Solderless Connection
I dont know if any of you have used solderless connections in your work? but that will save time and your pots, Acme guitar works use them in pre wired pickguards for strat's and they do the same humbucker as well.Last edited by greenfingers; 05-14-2008, 06:11 PM.
Originally posted by kevinT View PostI actually thought about this but instead of using the nuts, i was going to use gator clips...I think david schwab did something like this that he mentioned a while ago.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by kevinT View PostI am doing a lot of testing these days and i think i fried my volume pot with all the repetitive heating with the iron. What are the signs of a burned out volume pot? I'm getting thin and shrill tone from one of my guitars.
The classic trick for temporary hookups is to stick the wire to the terminal with only a drop of solder, without wrapping the wire around the terminal or poling the wire through the hole in the terminal. And do the soldering fast, so you don't heat things up too much. But I've never damaged a pot by soldering.
Originally posted by Joe Gwinn View PostI've never damaged a pot by soldering.
I recently bought a epi les paul studio to use as a test guitar. The pigtails, and mini-clips I put in make swapping pickups easy. I back the strings off enough to allow the tailpiece to clear the posts, and use a capo to hold things in place. I plan to add a couple more pigtails so I can try different capacitors also.
I get so tired loosening the strings that at some point, when I get the time, I want to make a bass I can slip the pickups in and out of with the strings on.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
