jcm800 clone with noise
  • jcm800 clone with noise
    Hi I have built a JCM800 clone with an original OT, four EL34, 100W and I have an issue with the presence control, if I put the control on a low value it make some loud noises. It`s worse if I turn up the master volume control. it don`t happen if I cut the Feedback wire. so I suspect is a weird problem of the power amp and the NFB.
    here is a sample of the noise.
    http://www.soundclick.com/fireland
    I also have some doubts about the wiring of the presence pot. in this layout there is DC through the pot , not like in the schematic.
    http://www.dreamtone.org/pdf/NEW2204...mDreamTone.pdf
    also in this one
    http://www.sonicdeli.com/ThunderTwea...fuellayout.htm
    I have checked voltages and it seems to be ok, unfortunately my oscilloscope only can measure AC.
    someone had any similar problem or have any idea of what more I must check?
    cheers
    Rafael
    Try reversing your plate wires on the output tubes. It's the wires that go to pin 3 of each output tube.
      I already did that , I had some power amp oscilations due the positive feedback.
      Rafael
        it seems like it should not be a particularly difficult build (since it's not too complicated). What did you do differently from the original? Maybe there might be a clue there.
          HI Dai, well it is almost stock , I put two 220uF 250V (with two 220k R in parallel) in serie for the first filter, I have done my own choke, also there is 0.1uF between PI and power tubes, 1ohm between cathode and ground for bias and 5.6k in the grids, I`m using a bridge rectifier and I have 430V at b+.
          cheers
          Rafael
            DONE! it was oscillating. I put a more big cap in c18 and problem solved.
            thanks for the help
            Rafael
              cool. Is C18 the 47pF in the phase inverter?
