Sovtek mig 50 issues ?
  • Sovtek mig 50 issues ?
    Just bought my first tube amp head some weeks ago.(noob)
    it's a sovtek mig 50 (orange edition) - no master volume.
    connected to a engl 412cab at 8 ohms.
    it was supposed to be unused, stored in russia for 20 years or so.
    the head looked fine, but had some issues :
    *The mains trafo is buzzing - quite alot
    *The mains trafo buzzes a little bit more, when turning standby on
    *Presence control is not responding - if i use a dirtortion pedal it is responding somewhat, but in reverse. (turning knob leftwise - gives more treble).
    Does anybody know if this is normal ?
    i'm thankful for any responses.
    Hey poffa,
    I also got the mig 50 orange edition. I have this hissing problem too. I didin't know if it came from the tubes or something else. I first changed the tubes and the sockets and rewired all of that. Sounded a bit better....but still this his when i turn it on. Even more when I turn the stand by on.
    I think it could be the same problem...
    Are you sure it comes from the transfo??
    We could help each other because I think we have the same mig 50 problem!!
    Keep in touch
    pyo
      Hello Pyo
      Yes, the buzzing(in my amp) comes from the mains trafo - I'm quite sure of that, as it is a mechanichal buzz. The Buzz was a bit reduced When I padded it.
      I also have hiss - but the hiss comes from the speakers, and only When standby is on. When standby is off - there's no sound from speakers.
      I have been told that these amps are supposed to make som noise..
      Is your hiss coming from the speakers, when Standby is off ???
      Maybe you have a problem with output trafo then
      Keepin' in touch
      Poffa
        pull out the power tubes....then turn it on. how's the buzzing compare to when the tubes are in place?
