How would you wire a humbucker for coil split using vintage single conductor braided wire and a second single conductor wire?
Wiring for coil split with vintage wire
Tags: None
I believe you would connect the second single wire to the series connection of the pup. Grounding that connection would cut off the coil associated with ground.
I"ve seen that alot in 70's pickups that were rewired like that for coil splitting, good point....http://www.SDpickups.com
Stephens Design Pickups
Personally I'd just use 4-conductor cable. It would be less work, and offers more choices for wiring the pickup.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
