I just biased this amp and put in all new sound tubes but I'm still get this crackly crunch sound out of it... All the wiring looks good so I don't know what it is. Any ideas?
Bad sound out of my 1964 Princeton
Does it crackle when you turn the controls? It could be the tube sockets are dirty or a noisy plate resistor in the pre amp section. There's also a resistor in the phase inverter section that's prone to break it's solder joint. Check closely all the ground wires that solder to the grounding plate where all the pots are bolted.
P. Did it make the noises before you put the tubes in? If not cleaning the tube sockets is a good call as well as replacing the old tubes one-by-one and see what happens. And don't forget dirty input jacks - just "sharpen" a pencil eraser and clean all of the contacts. And any other solder joints.
Rob
