Need help with my LP wiring (push pull)
  • Need help with my LP wiring (push pull)
    I've got 4 push-pull pots on the way and I made up the following diagram. I'm no expert so if you guys could tell if it makes any sense.
    Bridge Volume - Gets the two coils in the bridge pup in either parallel or series
    Neck Volume - Gets the two coils in the neck pup in either parallel or series
    Bridge Tone - Splits the coils (single coil) in either bridge or neck or both
    Neck Tone - Puts the bridge pup out of phase
    I figure the different configurations will be:
    Bridge series
    Bridge series + Neck series
    Bridge series + Neck parallel
    Bridge parallel
    Bridge parallel + Neck series
    Bridge parallel + Neck parallel
    Bridge single
    Bridge single + Neck single
    Neck single
    + all the out of phase options
    PS I didn’t include the multiple grounds
      Here is the latest version.
      Working on the coil split not sure it's ok
