Results 1 to 16 of 16
Thread: 5F1 Bias Resistor and Voltages?
    Junior Member
    Jan 2007
    8
    0
    I just finished a 5F1 clone and am wondering if I need to lower the 470 Ohm bias resister to get the current up.
    Here are my voltages:
    Pin 8 to Ground: 20.7v
    Pin 3 to Ground: 370.9v
    Pin 8 to Pin 3: 351.0v
    If I am not mistake the cathode voltage is pretty low and the watts dissipation on the JJ 6v6 is about 7 watts, half of what it can take. I am using a 5Y3 NOS rectifier. Thanks in advance.
    Supporting Member tubeswell's Avatar
    Feb 2007
    Wellington NZ
    4,201
    Blog Entries
    1
    Received: 132/0
    Given: 45/0
    18
    With the cathode at 20.7V with a 470R, you'll have 20.7/470 = .044A (44mA) tube current
    And if the plate is 370 and the cathode is 20.1, then you'll be dissipating (370-20.7)*.044 = 15.3W! (including screen) You want to aim to get somewhere between 12.5W to 13.8 W (assuming you have a modern brand of 6V6)
    So you need to get the plate voltage down a bit (say to about between 340 and 360). Best way is to to lower the B+ by putting in some reverse-biased zener diodes in series with the HT winding center tap to ground. Try a couple of 12V 5W diodes in series. (Make sure the banded end is pointing to ground.)
    Incidentally, What brand of rectifier have you got? Some '5Y3GTs' are not 5Y3GTs if you get my drift.
    Junior Member
    Jan 2007
    8
    0
    Is the high plate voltage do to the sort of universal Weber power transformer that I am using?
    I was the looking at the MM PT's and they had ones that were rated at 260-0-260v (Mid 50's) and 330-0330v (59 Tweed) which might be better all together. My 5e3's plate voltage is only 360v. 370v seemed pretty high for the 5F1 circuit.
    Jun 2006
    439
    14
    You could just increase your cathode resistor a bit. 600 ohms is
    not unheard of. I have 376v at the plate and use a 680 ohm
    cathode resistor, which gives me ~13w dissipation at idle.
    Paul P
    Junior Member
    Jan 2007
    8
    0
    I was way off on the 7 watts of dissipation. Wow! Well, I will just bump up the bias resistor and see how it does. Thanks
    Feb 2007
    Wellington NZ
    4,201
    Blog Entries
    1
    Received: 132/0
    Given: 45/0
    18
    Bumping up the bias resistor will have a different effect from lowering the B+/plate voltage. If you continue to have high plate voltage, it will be harder to overdrive the tube (which is okay if you like a cleaner amp).
    Old Timer
    Jun 2006
    3,315
    Received: 1/0
    17
    Clear Guy,
    You DON'T have a problem.
    You DON'T NEED to drop B+ voltage (obviously you can if you want), but 370v is not high for this kind of amp. You do not have high plate voltage. No champ ever had a 260-0-260VAC PT secondary. 350-0-350VAC is probably more realistic!
    You DON'T NEED to change your cathode resistor value. ALL champs had 470ohms. Unless your plate voltage (measured to ground) was significantly over 400vdc I'd stick with 470ohms. 660ohms should tame even the highest voltage champs (as Paul P intimates).
    In a design like this (SE, cathode biased), even a no name brand 6V6 will handle 20W plate dissipation, they do it all the time, for many reliable years in SF Champs with plate voltages in the 410v-430v region. I'm not saying that this is something to aim for (I actually have an 800ohm cathode resistor in my SF champ, but that runs at 440v from plate to ground with a GZ34), just putting a realistic perspective on things. 15-16W plate dissipation is no problem at all, yours is less than 15W as you have not accounted for screen current.
    Dividing cathode voltage by cathode resistor is not a pin point accurate way of measuring plate current/dissipation.
    Junior Member
    Jan 2007
    8
    0
    I may just leave it alone or use a 6l6 in there which would be fine. Its only getting used at low volume in my living room. Let it fly!
    Old Timer
    Jun 2006
    3,315
    Received: 1/0
    17
    If you switch to 6L6, be sure that the OT can take the additional plate current (6L6 will draw more current than 6V6 with same cathode resistor), use a 10W cathode resistor and a 100v cathode bypass cap on the power tube.
    I'd leave it alone, the 6V6 is not in any danger.
    Junior Member
    Jan 2007
    8
    0
    Thanks MWJB for the advice. Leaving it alone.
    Old Timer
    Jun 2007
    Pensacola, FL
    3,562
    Blog Entries
    1
    Received: 9/0
    Given: 4/0
    16
    Tubeswell. Why banded end to ground? I ask for lack of understanding. Zeners are generally oriented with the band towards the V+. So I'd put it in the opposite way as I understand it...which must be wrong. Thanks!
  12. #12
    Dec 2008
    Wernersville, PA
    12,940
    Received: 533/3
    Given: 288/0
    26
    The zener will 'lift' the full wave bridge rectifier from ground by the zener voltage.
    Oriented the 'proper way', you will simply get the diode drop.
  13. #13
    Old Timer
    Jun 2007
    Pensacola, FL
    3,562
    Blog Entries
    1
    Received: 9/0
    Given: 4/0
    16
    Yes that I understand. It's the orientation that's a ....surprise.
  14. #14
    Feb 2007
    Wellington NZ
    4,201
    Blog Entries
    1
    Received: 132/0
    Given: 45/0
    18
    try it and see.
  15. #15
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,134
    Received: 1,881/7
    55
    No, positive supply zeners are wired that way. Look at a typical +15 and -15 zener supply. You will find the negative supply zener wired reverse of the positive. Zeners are wired for reverse bias, so they break down at their zener voltage and conduct in reverse.
    In your typical 5Y3 supply, the current only flows one direction through the tube, and so only one direction through the transformer CT.. We want the zener to prevent conduction until a bite is taken out of the voltage.
  16. #16
    Old Timer
    Jun 2007
    Pensacola, FL
    3,562
    Blog Entries
    1
    Received: 9/0
    Given: 4/0
    16
    Yes indeed, that's what I meant with the "band towards the V+" the + saying positive. But ok so the current, even though this part of the circuit is technically AC, the current only flows one direction. Gonna see if I can wrap my skull chitlins around that one.
  1. need a smallish tube for high plate voltages, fixed bias
    By imaradiostar in forum Theory & Design
    Last Post: 04-22-2008, 04:28 AM
  2. 2n3904 bias resistor
    By Colonel_Sanders in forum Theory & Design
    Last Post: 04-01-2008, 09:46 AM
  3. HIWATT Bias Resistor Question
    By flying snake in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-21-2008, 12:26 PM
  4. Replies: 6
    Last Post: 01-25-2008, 02:43 AM
  5. 1 ohm resistor to measure plate current w cathode bias
    By studioit in forum Tweed Builders
    Last Post: 07-11-2007, 03:30 AM
