I was Wondering if its possible to put one humbucker and one emg active in the same guitar? and were to wire the passive on? i still have no idea as this is my first time iv ever modified my guitar.
Active and Passive
It can be done, but the EMG has a low Z output, and will load down the passive pickup.
The solution is to run the passive into a buffer first, essentially making it active.
If you really want to try it without the buffer, use a 250K or 500K for both pickups.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
