Marshall TSL100 Effects loop question
  • Marshall TSL100 Effects loop question
    Hi everyone,
    I have a question relating to the effects loop of my Marshall TSL100. It has two loops, one each for the clean and dirty but if you are only using one loop at the time it is recommended to use the clean channel loop.
    The drama I have noticed is that the volume is lower when using the loop on the crunch and lead channels (It's ok on the clean).
    When I turn the (crunch / lead) loop wet/dry mix knob up the volume is definitely lower than when the loop is switched off.
    Is there a way to overcome this by modifying the circuit of the effects loop for the crunch / lead channel to be louder?
    Thanks,
    Originally posted by BrotherJ View Post
    Hi everyone,
    Thanks,
    Hello, I'm sorry to bump a 10 year old thread but my tsl100 has this exact same problem. Any ideas? Thanks in advance.
      Hi. Welcome.
      Yes, my idea is to start a new thread for yours, starting with a complete description of what we are trying to correct.
        Hey, It's good to know when you subscribe to a thread it will still let you know when a reply is posted - even 10 years later!
        Sorry I didn't end up modifying the loop (I ended up selling my TSL100 & Cab back in 2009) but for the time I remember using a Tech 21 Boost DLA in the loop to bring the volume back up that little bit.
        Cheers
