Marshall 275 AVT Problem
  • Marshall 275 AVT Problem
    Hello,
    Was jamming the other day and all of sudden the amp just went dead.
    The amp will switch on but then i cannot press in any of the buttons (OD 1, ac sim, Clean, OD 2) so can't get any sound out of the amp.
    I'm guessing the problem is a blown fuse. Theres also a strong chance I have far too many electrical equipment items plugged into the same socket.
    How do I go about repairing this problem? Hoping its a simple DIY..
    Thanks in advance for any help. I have pretty much zero technical knowledge when it comes to this kind of thing.
    Cheers,
    Rob
    anyone got any advice
      If NONE of the buttons will light up, you most likely lost a low voltage power supply inside. If you can't use a voltmeter and solder parts onto circuit boards, you best refer this to a technician.
