Im starting to build a super reverb clone, however only utilizing the normal channel. Do those 220k resistors do anything other than keep the channels away from each other?
Fender mixing/summing resistors
Yep. You can leave out the resistor for a single-channel version.
220K would cause a slight drop in signal level. I'd be more concerned with the slight reduction in highs personally. However, if the signal level is where you want it, you can create a HF shelf response by bridging that resistor with a small cap, like 100pF silver-mica. It's really a spot you could experiment with freely with no ill effects.
