Any advice on how to do this in a standard push-pull 6L6 output stage and a long-tail PI? I tried it, applying a 820ohm resistor from the OT secondary back to the PI and I got a HORRIBLE screeching sound. Louder than all get out. Any help would be nice
Applying Negative Feedback
The feedback path you created was not negative, it was positive feedback - and that makes oscillation, the sound you heard.
"back to the PI" is not specific. That is about like saying I measured voltage on a pin of a tube. Without more specific information we can't tell what you did. Look at teh examples.Education is what you're left with after you have forgotten what you have learned.
Assuming you're not trying to apply too much feedback, in which case it'll oscillate no matter which way you hook up the OT leads. 820 ohms implies a LOT of feedback."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
Oh, the OP never mentioned that he took the whole PI from the Bandmaster. The feedback amount is set by the ratio of those resistors. 820 and 100 ohms suggests a closed-loop gain of about 9, which isn't so bad. If he used another PI with a larger resistor than 100 ohms in that position, the feedback could be a lot more."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
