Gretsch playboy amp vibrato problem
  • Gretsch playboy amp vibrato problem
    i have a gretsch playboy amp
    the vibrato makes a rhymthic sound which increase with a change in speed
    it sounds like a heart beat
    it is audible at mid intensity and gains speed as the speed is increase
    what might cause this and a possible repair idea
    thanks
    Is this a vintage amp or one of the new Victoria made units?
      gretsch playboy
      hi
      thanks for response
      unfortunately it is a new victoria model
      what do you think is causing that noise
      lordhoho
        Based on the schematic, the tremolo oscillator modulates the bias to the first pre-amp tube, instead of to the power tubes.
        I'd first try changing V1, the pre-amp tube and/or V2 the tremolo tube.
          gretsch playboy
          ok thanks will try that
            if nothing else works, it IS still under warranty, right?
              gretsch playboy
              no i bought it used
