Hi,
I'm building the dual rectifier 3ch and is about to fine tune the project. Ch1 and Ch2 are both working perfectly and sounds awesome! -all controls works properly at every settings. Ch3 is causing some problems. With the effect loop on the Output pot works as an overall Master volume, which makes it easier for me to describe what happens. The EQ is not as "good" as on ch2 and the Ch3 Master volume is not working properly. When it's turned between 9 and 11 o'clock the sound is ok, but as soon as I pass 11 o'clock the sound becomes flat and weird and volume begins to drop. At 12-13 o'clock I can make the sound "better" when turning the treble pot. If I pass 13 o'clock the amp sounds like a high frequency phaser with a tremolo with low depth
Any suggestions how to complete the beast?
Thank you
Thomas
Thank you
Thomas
