Anybody know where you can get a ceramic/cement .22 ohm 20 watt speaker resistor for the Fender Pro 185?
Fender Pro 185 need resistor
Originally posted by goal99 View PostAnybody know where you can get a ceramic/cement .22 ohm 20 watt speaker resistor for the Fender Pro 185?
Did you check Mouser Electronics or Digikey or Allied or MCM or ...
Mouser sells this, which would work, but would require mounting.
stock # 284-HS25-0.22
MCM: http://www.mcmelectronics.com/product/25WD22
It is 25 watts so check the physical dimensions.
Parts Express: http://www.partsexpress.com/pe/showd...number=017-.27
CLose.
Or stack a couple .47 ohm ones in parallel.Education is what you're left with after you have forgotten what you have learned.
