How much do I need to spend to get a good gauss meter? Are the $40 ones on ebay that people use for ghosts good enough? Or do I need something better? How simple, or complex does this thing need to be?
gauss meter... How much do I need to spend?
It's like anything else in the world. Buy crap and you'll be sorry. The Carlsen Melton is great, portable and cheap at $259
http://www.carlsenmelton.com/gm200a/gm200a.htm
sigpic Dyed in the wool
Originally posted by Spence View PostIt's like anything else in the world. Buy crap and you'll be sorry.
Are there any other brands I might want to look into? I'm a luthier that is tiered of buying other people's pickups to put into my guitars. I want to be able to say I made it all myself, so I'm willing to drop the money for good equipment that does everything I need.
There are plenty out there but they mostly use a probe on a wire. The thing about the Carlsen Melton meter is that the probe is entirely encased in the top of the unit. This doesn't allow you to measure gauss in awkward places but it has the huge advantage of being protected.
I make a lot of pickups so what do I use? A Carlsen Melton. It's perfect for the application and small, portable and reliable. that's my recommendation.
To get a true indication of a magnet's gauss with it you need to move the probe over the entire magnet polar face. I love this meter and wouldn't change it for anything else.sigpic Dyed in the wool
Tools I use :
Soldering station which will reach 840 F or 450 C.
Extech Meter
DCR Multimeter
Solder Sucker
Stanley Knife
Plastic and rubber faced hammer
Pliers
Wire strippers
Files
centre punch for flairing eyelets
Sheet steel hand nibbers for cutting custom flatwork
Grinder and sander for sizing and bevelling magnets
Pillar drill
Battery powered drill
Sandpaper 600 grit
Wax melting pots
large neodynium magnets for charging alnico
calipers
bright worklamp
From my perspective, these are essential tools but you could get away with less. I also have some other gear. These are primarily for more ambitious projects.
ie. I have a flypress which can be used to shape sheet metal into things like PAF covers or for cutting flatwork with cutting dies. I also have a vacuum former for making plastic pickup covers. Things like this are not necessary but it's easy to get drawn into making things yourself.sigpic Dyed in the wool
Extech Meter
DCR Multimeter
Solder Sucker
Stanley Knife
Pliers
Wire strippers
Files
Pillar drill
Sandpaper 600 grit
Wax melting pots
calipers
bright worklamp
I've got all that except for the extech meter. what exactly does that do?
huh?
12,000 gauss isn't a magnet you'd put in a guitar pickup unless its real tiny. Your average strat pickup pole fully charged might hit 1200 guass, most are way under that.
Add to Spence's list a magnetizer, I got one recently and really love it.....http://www.SDpickups.com
Stephens Design Pickups
Originally posted by corduroyew View PostI've got all that except for the extech meter. what exactly does that do?
You see these figures quoted on some pickup maker's websites.sigpic Dyed in the wool
Originally posted by corduroyew View PostI'm a luthier that is tiered of buying other people's pickups to put into my guitars. I want to be able to say I made it all myself, so I'm willing to drop the money for good equipment that does everything I need.
The last thing was the pickups, and I didn't like what I was using, so I made my own. For my bass they sound perfect... they sound like the bass.
The next step is to make my own hardware, but I'm stopping at the tuners. No point in reinventing the wheel... but bass bridges... yes! They are way too expensive and I'm not crazy about most of them. And always either too wide or too narrow for my basses.
Hey guitar companies use to make their own parts... now, for the most part (pun intended) we use parts that are copies of Fender and Gibson parts.
I don't want Fender and Gibson style parts on my guitars!It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
