Vox AC-15 Problem
  • Vox AC-15 Problem
    I have a late '90's or early '00's British made KORG?Vox AC-15. Recently when I used it, the volume started getting lower as I played it. It had done this before, but seemed to be OK with a different cable. Now I'm thinking it might actually be the amp. Any suggestions?
    Korg USA only DISTRIBUTES Vox amps in the USA, they don't make them.
    As to the symptom, it could be a million things. Check solder to the jacks, the controls, make sure the tube sockets aer tight, etc etc.
      Also, check the tubes themselves.
