Dose anyone know where to find a chart that shows the interchange and numbers of tubes.I ordered a set of 6L6 GC tubes for my Bassman Ten and got a pair of 6N3Cs.I putt em in and they sound good.I want to know if I can swap the 12AT7 for a 12AU7 just to try some diferent tones.Thanks for any help.
tube ID interchange
Originally posted by shovel View PostDose anyone know where to find a chart that shows the interchange and numbers of tubes.I ordered a set of 6L6 GC tubes for my Bassman Ten and got a pair of 6N3Cs.I putt em in and they sound good.I want to know if I can swap the 12AT7 for a 12AU7 just to try some diferent tones.Thanks for any help.
If you Goggle 6N3C you will find lots of information.
I'd say that you can swap a 12AT7 for a 12AU7. The 12AU7 is usually used in driver situations and is not really known for being used in a location that is responsible for much tone. If you post the amp model and location in the circuit I'm pretty sure you will get some good advice.
Tom
http://www.machmat.com/sales/6l6.htm
In Russian they are 6П3С, the second character is a "P" sound, the fourth is an "S" sound in the Cyrillic alphabet.
I've never heard anything but bad things about the 6П3С, but have never personally tried them. YMMV.
The 6П3С-EB is the millitary version rated for long life and mechanical durability. It is the same tube as the Sovtek "5881."
As far as equivalents go, download this software:
http://www.duncanamps.com/tdslpe/
When you plug in a tube number, it gives you tube data, equivalents (both close and identical) and pinout. It will aslo give you a list of tubes with the same pinout.
steve
