Fender Champion 600 Switch
  • Fender Champion 600 Switch
    The On-Off Switch on my Champion 600 broke. Does anyone know where i can get a replacement switch? It says "AT" on the top. "Pronic" on the bottom. And " 15A 125VAC"
    "10A 250VAC" on the face.
    I don't know if Fender is selling loose parts for those yet or not, if they are, you can order it from any Fender dealer.
    However, it is just a switch, and if you take the dimentions of it overall and the dimensions of the hole is snaps into, you should be able to find a replacement in the Mouser catalog.
    And if it is a double section switch and they are only using one side of it, the other set of terminals might still work, and then moving the wires over to them is all it takes.
      Fender sells NO parts for the Champion 600. You can get a replacement from Radio Shack.
      John R. Frondelli
      "Mediocre is the new 'Good' "
        Thanks guys. I'm going to try radio shack.
