I'm assembling a Tele and am about to wind the pickups for it. The polarity on the neck pickup is south up and the bridge north up. Were the early Tele's wound for humbucking effect?
Early Tele pickup wind direction
int main(void) {return 0;} /* no bugs, lean, portable & scalable... */
www.ozbassforum.comTags: None
Looks like they weren't. Same polarity, same wind direction(?). Did the neck and bridge pickups have opposing polarity from the late 60's onwards?int main(void) {return 0;} /* no bugs, lean, portable & scalable... */
www.ozbassforum.com
You might as well make them RWRP. It doesn't alter the tone, and you get the benefit of hum cancelation when they are both on.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Thanks for that, it's exactly what I did. The Tele is now assembled and I'm getting used to the sound. When I play guitar (writing and recording only), I usually use a FrankenStrat that I assembled from various parts with pickups I made which has a very different sound to the Tele. The bridge pickup is kind of shrill, first one I've wound, so need to work on that.int main(void) {return 0;} /* no bugs, lean, portable & scalable... */
www.ozbassforum.com
Originally posted by mkat View PostThanks for that, it's exactly what I did. The Tele is now assembled and I'm getting used to the sound. When I play guitar (writing and recording only), I usually use a FrankenStrat that I assembled from various parts with pickups I made which has a very different sound to the Tele. The bridge pickup is kind of shrill, first one I've wound, so need to work on that.
The Tele has old Bill Lawrence L-250's in it, and (more recently) a stacked bridge pickup I made.
I like Teles .... they have a nice snarl.
Nice work there David. I may be wrong, but I think I may have heard your Tele in one of your recordings. Turning down the tone control takes away that shrill, but I'm going to try for a slightly hotter bridge this time and maybe even a stack (thanks for the idea).
My Tele is a two piece swamp ash body, one piece maple neck, with '67 wiring (I'll be trying different wiring schemes too once I wind the next bridge pickup). It is bright sounding compared to my FrankenStrat (alder body). I made the white pickguard, but I'm going to replace that with a black one once I get the pickguard material (tried a few pickguards and none line up right to the control plate, so decided to make one). Still waiting on the string tree. Here it is with the pickups I wound:int main(void) {return 0;} /* no bugs, lean, portable & scalable... */
www.ozbassforum.com
Nice looking Tele! My guitar has a back story; I was going to make a standard Tele with the transparent white finish and ash tray bridge... just as I remembered the first one I ever saw. Then my partner said "why not ust buy some parts then?" and that made me think I needed to do something more custom, so the maple top came to mind, and then the set neck.
Then I decided to alter the body shape, so I threw in the Jazzmaster style slope, and a Gibson style lower body horn. The swamp ash body blank was thick enough for a normal guitar, and my planer wasn't wide enough, and I didn't feel like ripping and re-gluing it, so I chambered it and left it thick. So it evolved as I went along, which seems to be true of everything I make.
Originally posted by mkat View PostNice work there David. I may be wrong, but I think I may have heard your Tele in one of your recordings.
The other guitars are a Charvel Strat that had 2 covered DirtyFingers (on "I Close My Eyes") and a Strat type guitar I made for someone on "Bass Head".
Here's the Tele. This is about the only thing I have with it recorded... not sure why that is! This was from about 1998, so it has the original lead pickup.
Song2
Turning down the tone control takes away that shrill, but I'm going to try for a slightly hotter bridge this time and maybe even a stack (thanks for the idea).It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
There is a disadvantage sometimes to RWRP in that you often get a volume drop if the pickups are too well matched. In strats this is probably more apparent, personally I don't like RWRP in strats, you get a richer tone in the 2 and 4 positions and no volume drop...http://www.SDpickups.com
Stephens Design Pickups
Originally posted by Possum View PostThere is a disadvantage sometimes to RWRP in that you often get a volume drop if the pickups are too well matched. In strats this is probably more apparent, personally I don't like RWRP in strats, you get a richer tone in the 2 and 4 positions and no volume drop...
doesn't affect the neck and bridge on their own. I only like RWRP for rhythm
on certain style of music only, prefer the neck or bridge individually for
rhythm and lead. Keep in mind that I'm a bass player, well, my main instrument is bass that is .
Originally posted by Possum View PostIn strats this is probably more apparent, personally I don't like RWRP in strats, you get a richer tone in the 2 and 4 positions and no volume drop...int main(void) {return 0;} /* no bugs, lean, portable & scalable... */
www.ozbassforum.com
Originally posted by mkat View PostWould that be out of phase though?It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
I wound the bridge pickup hotter tonight, possibly too hot, and the shrill has just about gone. Much beefier.int main(void) {return 0;} /* no bugs, lean, portable & scalable... */
www.ozbassforum.com
Oh, the thrill is gone baby. Baby its gone away for good...well, for now anyway...Although I'll still live on but so lonely I'll be...I may want some back...int main(void) {return 0;} /* no bugs, lean, portable & scalable... */
www.ozbassforum.com
Originally posted by David Schwab View PostMy first stack wasn't as hot as this one, and sounded like a stock tele pickup... I wanted something hotter, so the new one is wound with as much 43 as I could fit on the bobbin. Now I have some 44 so I'll probably wind a new one. But this one sounds a lot fatter.int main(void) {return 0;} /* no bugs, lean, portable & scalable... */
www.ozbassforum.com
