HH with push-pull DPDT, cap for H and S possible?
  • HH with push-pull DPDT, cap for H and S possible?
    Hello,
    I have a Tele with two humbuckers, one Volume and one Tone that pulls up for pickup splitting (both pots are 500k). Is it possible to have 0.047uf in H mode and 0.022uf in split mode? The current cap is a mallory 150 at 0.022 and the H mode is a little too bright for me but when I use a mustard 0.047 then the H mode is nice but the S mode is too dark.
    Thanks in advance!
    Tom
    You could put in another push/pull and wire each pickup with its own splitter, then use the second halves of the switches to change the value of the tone cap, or find a push/pull pot with three poles.
      I ended up putting in a .022 and .01 ceramic in parallel and an am very pleased with the result in H and split positions. Thanks for the input, just the same.
