...don't know about the THD device, but Ted Weber's Coppercap™ units provide a linear-approximation of what is actually a power-exponential curve...it's close, but not "exactly" the same voltage "drop" versus current load.
...while some people claim to be able to "hear" a difference between a 'real' vacuum tube rectifier and the Coppercap™, I have to say that I couldn't HEAR any difference, even though I was certainly able to measure and record real-world differences on my o'scope and digital screen captures.
thanks OTM. Sorry, I'm basically a idiot when it comes to math, so I can only sort of see that the voltage into the tube will be multiplied by the Perveance(seems the bigger the cathode and plate, plus the closer they are the bigger this value?) and I don't undertand the "^(3/2)" coming after that.
^(3/2) is an old way of entering exponents from back in the days of line printers, teletypes and punched cards (usually called IBM cards). So 4^2 would be 4 squarded equals 16. This board has no way to enter super and sub scripts unless there is a way to do it in html. If anyone can enlighten me, that would be great!
WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel. REMEMBER: Everybody knows that smokin' ain't allowed in school !
I didnt understand any of the stuff you guys where talking about but i did order the Weber 5U4GB Copper Cap Moduler and will post my findings after installing it. Im hoping it will warm my amp up a little. at the very least it has to be better than the orignal diode rectifier that is in the amp. I have a silverface 72 bassman head that i turned back to the blackface specs.
SRV baby
thanks
keith
...a man after my own heart! -- when the facts (or theory) make no sense, we just go out and "...TRY IT..." approach.
...looking forward to hearing your results.
...here's how I do it, I use the 'hidden' Microsoft "ALT-key" keyboard method:
1) Turn 'on' the keybord NUM LOCK function to enable the numeric keypad.
2) Then, while simultaneously holding 'down' the ALT-key, enter 4-digit numeric character-code on the numeric keypad and then release the ALT-key; NOTE--the leading ZERO ('0') must be typed.
3) When done, don't forget to turn NUM LOCK 'off' again.
Could someone please tell me how to hook up the reactive rectifier?
I read that it was to replace the solid state rectifier but I don't see how. It looks as though it is added to the existing circuit. (Is this correct?)
