Hi all, I just picked up a Gibson Duo-Medalist for something to fiddle around with. Price was right and I couldn't pass it up! It's all original, right down to the tubes.
3 x 6EU7, 2 x 12AU7A, (these 5 are the preamps/reverb driver/tremolo driver tubes) 1 x 12AX7, (I believe phase inverter) 2 x 7591. (power, of course!) SS rectifier.
First problem is volume... there's hardly any of it! It has two channels, one "Normal" and one "Reverb/Tremolo". If I run my guitar into BOTH channels, I can get a decent volume. Looks like each channel uses 1 of the 6EU7s for signal before the power amp, the other 3 (12AU7s and 6EU7) are for tremolo and reverb. Is this just a result of not enough gain stages in the preamp? I'm going to replace both of preamp 6EU7s and make sure the power tubes are good and biased correctly sometime this weekend. What else should I be looking at that could cause this lack of volume? I think this amp was designed to be clean, but some people (I'm talking about Harmony Central reviews here) say they get a great overdrive, others say they can only get clean - I seem to be in this second group!
Second problem is the TREBLE. This thing brings a new meaning to Ice Pick! The knobs go to 12, I keep the Bass on 12 and the Treble on 1-2 and I still have to roll off a decent amount on the guitar tone knob. Looking at the schematic, there's something I don't understand, after the first triode and tone stack and before the second triode that goes to the power amp - is this some kind of filter? I'm still learning about these things...
I've attached the schematic with the components I'm unsure about circled in black. Any ideas what this does in the circuit?
Anyway, hope you guys can help me out a bit, I've found plenty of info here and in the archives before, but this time I actually had to register to ask!
