0
Thumbs Up/Down |
Received: 0/0 Given: 0/0 |
HI Ive got an old CRATE TD 70, tube preamp SS power amp.Everything works fine but after an hour or so of playing [either loud or quiet] it fades out to nothing over a period of about 5 seconds, not instantly.If I plug a lead into the line out socket it crackles,pops etc comes back to life, but only for 5 or 10 minutes then fades out again. Ive replaced the 12ax7 preamp tube but as far as ive got.Any Ideas THANKS SCOTT
Thumbs Up/Down |
Received: 1,901/7 Given: 0/0 |
If you have a jack marked power amp in or effects return or even insert, clean its inner contacts. I would suspect it is failing.
Thumbs Up/Down |
Thanks enzo, I pulled the chassis out and wd40'd all the jacks[which by the way are the wierdest jacks ive seen,enclosed complicated looking]Amp went for 3 hours straight ,no problem Thanks again SCOTT
Thumbs Up/Down |
Hi there I had the same problem with my TD70 and found it to be the voltage rail zener diodes which were failing the longer the amp ran they are IN5353B type fault was the same fading out low volume then back in for short period loud as hell you'll find them top left on the board I'll attach schematic and board layout you'll probably find evidence of overheating on the P.C.B. around them.
Thumbs Up/Down |
Received: 1/0 Given: 0/0 |
Oh my GAWD....do we need to go thru THIS again?
FFS, DO NOT USE WD40 for *anything* involving electronics. It is NOT electronic grade contact cleaner, its a cheap lubricant. And it turns into a goop that attracts dust/dirt.
What you need to do now.....get some cleaner/degreaser that won't attack plastic. Naptha (wick lighter fluid <Zippo type>) works pretty well. Flush out the jack several times while working the contacts to get that shit outta there.
This stuff is cheap and works well to clean jacks and pots as well as other connectors:
GC Electronics - 19-638 - Chemicals - Chemicals & Adhesives - Allied Electronics
Now....what you shoulda used the first time:
Amazon.com: GC Electronics DE-OX-ID Contact Cleaner (4 oz.) : 19-1906: Electronics
Thats the stuff that will actually deoxidize contacts.
NO WD40!!!!!
Thumbs Up/Down |
Received: 3/0 Given: 0/0 |
By the way thanks for the schematic. I had no luck finding it some time ago.
Thumbs Up/Down |
Relax, that WD40 comment came from a 2008 post.
Thumbs Up/Down |
Heh....didn't even look at the date. At any rate....people should know that WD40 has no business being used as a contact cleaner. I tend to get fired up when I hear of this happening....
Thumbs Up/Down |
Well, no wonder... WD40 is flammable. (No drummer pun intended) Not the stuff to have around if it gets you fired up.
Thumbs Up/Down |
I Got the amp fixed ..[one of the best little amps Ive ever had] and I sold it. The Guy who fixed it said it was a transformer problem.[I think maybe bullshit] Thanks for the replies and info regards Scott
Thumbs Up/Down |
good day
can you send the file to my email maxivanegas.yupi@gmail.com does not let me download attachments
thanks
Thumbs Up/Down |
Received: 1,682/24 Given: 4,330/11 |
Here is the schematic: https://music-electronics-forum.com/...5&d=1560974103
Just because they don't have tubes doesn't mean they don't have feelings! - glebert
Thumbs Up/Down |
Thumbs Up/Down |
Received: 349/5 Given: 239/0 |
If the manufacturer doesn't supply a board layout then I don't think you will find it.
https://supportloudtech.netx.net/fil...nal/attachment
Thumbs Up/Down |
Received: 1,124/102 Given: 152/36 |
Binkie McFartnuggets:If we really wanted to know the meaning of life we would have fed Stephen Hawking shrooms a long time ago.
Thumbs Up/Down |
Received: 535/3 Given: 290/0 |
Thumbs Up/Down |
