Hi again. Just about finished my first cab. Pleased with result. Cant do any more until kit arrives in a few weeks. Kit is 5 watts. What wattage speaker would be best. As you can tell I am a novice when it comes to valve amps so sorry for all the questions but I am learning a lot from all your replies. Thanks.
Speaker Wattage
Your main concern should not be wattage, but voicing. Different speakers produce different sounds. Two basic categories are British & American, their are several versions of both (Celestion, Jensen, JBL, Weber, Eminence, Ware House, etc); and then there is magnet type: alnico, ceramic and now neodymium, each one effects the sound (& weight) in slightly different ways.
What you probably need to do is tell us what kind of amp your building and the size of speaker, and how much room you have in the cabinet, and then people can offer up their personal (subjective) preferences for that style of amp and size of speaker. After that wattage is a simple matter, if there are options in wattage available for the type of speaker you can just go with the lowest power rating.
to confuse you even more
guitar amps and the like don't use HiFi speakers. They use musical instrument speakers.
if you hook a MI speaker up to your stereo i'tll sound like mud! but boy oh boy hooked up to a tube amp and they sound amazing!
you see an amps speaker is the final ingrediant into the "TONE" equation.
first is the instrument itself and the cable.
second is the amp
third the speaker.
all of these have HUGE influences as to what the over all sound will be and changing any one of those ingrediants can give you drastic changes.
HiFi speakers on the other hand are designed NOT to flavor the tone of music. they re-create the music that has been made.
get it?
so like HASSREL suggested.. what flavor are you looking for?
Many Thanks for replies. Tone? Probably after the `Ultimate Strat Sound` whatever that is!! Seriously though something akin to Messrs Knopfler, Marvin, Gilmour. Love playing clean Am Std Strat, your advice is much appreciated, but as you say the speaker is only one part of the equation. As this is my first valve amp build I dont want to spoil it by buying unsuitable speakers etc. The owner of the amp kit place suggested a Celestion G12, which are not too bad on price, so may take his advice. Thanks again.
Kit is from Ampmaker in the UK (www.ampmaker.com) £140 with some very good online instructions. He only does a 5 watt and an 18 watt at the moment, so as its my first valve build I`ve gone for the 5 watt (Its only for home and occaisional jam with friends) Gets some good reviews on Harmony. As I said he suggests a G12H speaker so may go with that. Must admit that cab making is addictive. Managed to beg 3/4" plywood from a customer, so hasnt really cost me anything yet apart from my time. Will keep you posted on progress later as cant order kit until April as he is so busy. Cheers
HAHAHA!
some one caught the bug
anyone who claims any kind of work is addictive or could be has already been bitten.
it looks to have Marshall topograghy and will likely have that classic "British" sound so a Celestion or Celestion copy would harmonize nicely
simple tube or valve amps like yours lend themselves to endless modifications to change thier sounds, quite a bit like changing pickups , strings and volume and tone controls in a guitar.
You're going to be amazed the first few times you play your amp if especially if you never played a tube amp before, what i find humorous is when my son's metal head buddies suddenly want to play on his little 15 watt amp and make comments about how the amp sounds better than thier such and such effect pedal
it will only get better and smoother too the more you use it, the speaker will break in and the tubes will take a set. a month of playing and you'll hear richness warmth and depth that you've never heard before.
keep us posted on your progress and post pics if you can.
we'd all love to see your cab too, lots of fine craftsmen here can help you hone your skills.
Thanks for replies and encouragement. Im presuming that at 5 watts I can crank it if I want to without blowing the patio doors off!! Will post pic of cab as soon as possible. Afraid its not fingerjoints as I dont have the tooling, so its butt joints screwed glued and dowelled and its bang on 90 degrees at every corner! Not bad for a first attempt.
Looking at your "Fender'ish" cab, and that you want an "Ultimate" Strat tone, I would suggest finding a late '50's early 60's Jensen P12R. An old alnico with a very "tight" cone and very "light" voice coil have such amazing dynamics the guitar just links up with the speaker and they become one sonically.
Oh, one other thing, old radio speakers can work very well driven with a low wattage amp. I used to find them at flea markets, and was surprised at thier tone.Last edited by guitician; 03-06-2009, 05:19 PM.Now Trending: China has found a way to turn stupidity into money!
Originally posted by guitician View PostLooking at your "Fender'ish" cab, and that you want an "Ultimate" Strat tone, I would suggest finding a late '50's early 60's Jensen P12R. An old alnico with a very "tight" cone and very "light" voice coil have such amazing dynamics the guitar just links up with the speaker and they become one sonically.
Originally posted by a1terrier View PostThanks for that Guitician. Think the kit will take 8 ohm or 16 ohm. Whats the
one to get??Now Trending: China has found a way to turn stupidity into money!
'Im presuming that at 5 watts I can crank it if I want to without blowing the patio doors off!'
Not a safe assumption. 5 watts clean will be nearly 10 watts when cranked, into a 100dB/W speaker = ~110dB, which will have the ornaments dancing off the shelves at least.
100dB/W means that 1 watt will create 100dB soundpressure level at 1 metre, therefore
2 watts will be 103dB, 4 watts 106dB, 8 watts 109dB. Add 3dB every time power in is doubled.
If you want to be loud (ie keep up with a drummer) you need an efficient speaker (100dB/W ie G12H30), whereas if you want a cranked tone at more domestic friendly levels (jamming with a buddy), you need a lower efficiency speaker, say a Jensen P12R at 94 dB/W. Peter.Last edited by pdf64; 03-07-2009, 01:26 PM.My band:- http://www.youtube.com/user/RedwingBand
