Mounting Mini-humbuckers in standard size hole
  • Mounting Mini-humbuckers in standard size hole
    Hello, I was referred here by someone at Aron's stompbox forum.
    I'm interested in putting a mini humbucker in place of a standard sized one (stock pickups on an Ibanez semi-hollow body to be exact). Is this at all common? Are there specialized brackets that allow for this? Any information would be appreciated greatly.
    Thanks,
    Ian
    Firebird; Pickup Mounting Rings | Allparts.com
    Most Firebird and deluxe style mini humbuckers share the same sized baseplates
      Would that cover the existing large humbucker rout?
      It might need a custom mounting ring.
        You're right David. That not the right one. There are special rings for mounting a Mini HB in a standard rout, but the on in the link isn't correct. Ian, you shoul'd look for something like this:
        Got Guitar Parts? : Guitar Jones USA
        althou I do not recomend this suplier as he has ripped of at least two members of this forum.
