hi.. i'm a noobie here.. i wanted to ask a question on changing the speaker of an amp.. i've been browsing here, but it seems that i cant understand many of the term, plus i dont have any expirience with modifying amp and electronics stuff..
my problem is that i have this small solid state amp that uses a 9volt battery n i'm not sure much is the watt of this amp.. its a cheap amp.. the problem is that the speaker produce a cracking sound, i guess the speaker is damaged.. so i was thinking of changing the speaker.. its stated 0.5w, 8 ohm on back of the speaker..
My question are:-
1. can I change the speaker with a higher watt but have lower ohm?
2. will changing the speaker produce different sound?
dats all for now.. i hope u guys can help me with this problems. thanks
My question are:-
