Transformer load question
  • Transformer load question
    Is it safe to run a 8 ohm load on my bassman that has a 4 transformer?
    Thanks
    baddog
    It should be. You will lose power. Most amps will accept a 1/2 or 2x load without failure. I do it all the time. Some players do it because they prefere the tone. But...
    There are alot of different "Bassman" amps. Some may be more finiky than others. I don't know enough about all the different Bassmans to be 100% sure.
    Chuck
      I've done it and I would say yes. Putting a higher resistance on a amp should not hurt it. Putting a lower resistance on an amp would increase the load on the amp and I would think that could cause stress on the output transformer and output tubes.
      Crate V33h, Peavey Classic 30h & 100h, Traynor YCV20WR
        Actually it's the other way around. Running an amp into too high an impedance or an open load can cause arcing in the OT. Too low an impedance or a short will be harder on the tubes but won't generally harm the OT. Most PA failures caused by impedance mismatch are due to too high an impedance or an open load, not too low an impedance or a short. In fact, many MFGs use a shorting jack on the speaker output so that if you try to run the amp with no speaker plugged in the amp will be running into a dead short rather than an open load.
        Chuck
          What he said.
          Remember, this is for tube amps. On SS amps, usually there is a minimum load - you can go higher and even open (no load) without damage.
          HTH
          Albert
            Yea, what Albert said too
            Chuck
              Thanks to all who replied
              BAddog
                Chuck,
                I stand corrected, Thanks for the clarification!
