Anyone know what the "tiny terror" circuit is?
  • Voltages
    Originally posted by Thomeeque View Post
    Original is around 180VAC IIRC, so I'd use those 164VAC. It should be still in usable area with just slightly lower power, which is IMO good thing
    Good luck, T.
    Hello,
    finally I read the entire post, still I have a doubt about the power trafo.
    Before in this post, a schematic has been posted. The schemo showed voltages of:
    -A: 325V
    -B: 320V
    -C: 290V
    -D: 265V
    Now you say that A = 180V.
    1) Which is correct??
    2) Can that difference be due to different versions of the OTT??
    3) If you know the A voltage, is there a way to calculate B, C and D without measuring or simulate with Spice??
    4) How have been calculated the voltages in the previous example??
    • Hey there,
      does anybody have a schematic of the Dual Terror so far? - I´ve read some speculations that it is basically two Tiny Terrors (even two PIs!) with just no bright cap on the fat-channel.
      Can anybody confirm that?
      Cheers
      Konny
      Crank it up! - Go Shake, Rattle & Roll
      • Originally posted by ciambom View Post
        Hello,
        Hi! Sorry, I have missed this post for some reason It's probably passé for you now, but I'll answer anyway..
        -A: 325V
        -B: 320V
        -C: 290V
        -D: 265V
        These are DC voltages measured in 15W mode.
        This is AC (RMS) voltage before full-wave rectification and filtering for 7W mode.
        Simplified VAC to VDC conversion formula for this situation is: VDC = sqrt(2)*VAC = 1.414*VAC
        So 325VDC at A means, that there's 230VAC at rectifier (D1-D4) input
        and
        180VAC at rectifier input means 255VDC at A. Actually I'm not sure about those 180VAC, this may not be accurate value.
        For more read e.g. Rectifier - Wikipedia, the free encyclopedia
        You could try to recalculate it by using 325:320:290:265 ratio, it won't be perfect but maybe good enough - why do you need it?
        What example?
        T.
        • Hi Thom,
          you're right: time has passed and now many aspects are clear.
          However thank you for the answer.
          I'm read to build the parts and bulit it, I only would know your opinion about:
          1) power transformer: VT1185
          Valve Transformer VT1185
          this trafo it's amazing, look at the current capability
          I'm not interested in 7W mode, so this should be perfect.
          Hammond just makes trafos with center tap and very poor current capability...
          2) output transformer: Hammond 1760E
          Tube-Town Online-Store - Hammond 1760E Fender OT 125A10B / 022913 UPGRADE Princeton ha1760e
          it should work, but it would be a "Fender style" trafo mounted in a TT, what do you think about??
          3) circuit: I made a 2 layers PCB design with a ground plane. Do you see problems with it?? A star grounding would be better?
          Thanks,
          Marco
            Hi Thom,
            I believe that you *could* go with Hammond PT 260E (225-0-225V/100mA) because thanks to the full-wave rectification on center-tapped transformer (where each winding works only for 50% of the cycle) you would get 200mA effectively, but there's no reason really - VT1185 looks like it gives what you need (with nice reserve) and is cheaper.
            What mains voltage you will use?
            Looks perfect to me!
            But "Fender style" trafo mounted in a TT question is a way below my discrimination ability, I'm far from being such an expert to answer anything valuable here
            Again, I don't think I can answer this due to my limited knowledge. Proper ground plate can probably work as good as proper star grounding, but you don't see it much in tube
            amps (e.g. original OTT uses 2 layers PCB without ground plate), maybe it is more inclinable to parasite capacitance issues? I would go with star grounding probably.
            Thanks,
            Marco
            My pleasure, please don't forget to show us result when your TT is done (or even soon )
            T.
            • Originally posted by Thomeeque View Post
              T.
              I will use the 240Vac primaty for the main, and the 260Vac for the secondary High voltage, it will be a little higher than the original TT (250Vac) but later I'll put a 150ohm 6W cathode resistor on the EL84s to keep the tubes a little more quiet.
              Meanwhile I found another OT which seems more suitable for the "little bastard", I think I'll go with that:
              18W push pull output transformer
              For sure I will inform you as soon as I will complete it.
              Stay rock,
              M
              • Problems
                T.
                Hi Thom,
                finally I did it, but I have a couple of problems:
                1) if I rise the gain up to nine/ten o'clock the amp start to fizz at very high freq, the sound stop rise the gain&volume and the resulting sound is a mix between the guitar signal and the fizz. If I play a chord, the wave doesn't end but is broken by the fizz.
                2) if I turn clockwise the tone pot, the sound progressively looses volume until turning completely-off, I connected the tone pot like your amp: before master volume section and connecting only the pins 1 & 2, the pin 3 is unconnected.
                Erroneusly I buyed a dual gang-tone pot, but I use just one-half leaving the other half completely connected to ground.
                If you have an idea of what could be..I will be grateful!!
                (I could send you the schematics and some fotos if you want).
                Thanks,
                Marco
                • Tone control issues
                  Do you mean like this:
                  I did implement it this way too, it seemed more logical to me and it works well.
                  I wonder if AdmiralB's scheme is correct at this point, but I cannot check it, I don't have access to original OTT..
                  T.
                  I used this way for my build, but it seems ineffective, which pin is connected to C11? and which pin is leaved unconnected??
                    Wire it this way, it's IMO best:
                    It does not matter which wire goes to C11 and which to C10 plus C12 (2n2) could intterrupt the other wire, it does not matter as well..
                    Good luck, T.
                      Hi Thom,
                      Thanks,
                      Marco
                      Hi Marco!
                      Ad 1 = parasitic oscillation - this is a common issue with tube amps, high-gain tube circuits are very sensitive and you have to be careful when building one. There is some unwanted feedback in your circuit leading to self-oscillation. Feedback is either electro-magnetic (one part /e.g. output transformer/ works as an transmitter and one part /e.g. input capacitor, input tube../ works as an receiver) or electrical, typically transfered via supply or ground wires. To detect the first case try to tune amp slightly above the border where self-oscillation starts and then tap by some isolated (wood) stick to parts and listen, if tapping on some part affects the oscillation. The other case is more complicated to detect. Let's check the first one first.
                      Note: I'm not expert on this at all, it's just the way I understand it and what I would try - google for parasitic oscillation in tube amps to get more precise/rich/correct answer..
                      Ad 2 - dual pot does not matter. You must have made some mistake when wiring the tone pot - either you have not used C12 capacitor in series with the pot or you have used wrong (much bigger) value of this capacitor (it should be 2.2nF = 0.0022uF).
                      Good luck, T.
                      PS: Yes, hi-res photos and schema could be very helpful here.
                        Hi Marco!
                        Good luck, T.
                        Hi Thom,
                        I'm sure it's a problem of V1.
                        I put a passive serial fx-loop in the amp, so I connected the guitar at the Return jack and play bypassing V1. The sound was clean and loud without noise even with the volume at max. If I turn-on the gain pot, the noise starts but it doesn't affect the signal, it's just added to the signal.
                        I tried to tap the tubes, trafos and pots with a pecil while the amp was fizzing but the taps didn't affect the noise, so I think it's a matter of electrical feedback.. sigh
                        Well.. I attach my schematic which is almost the same of yours.
                        My schematics only contains PCB elements, so you won't see potentiometers, jack connectors, trafos, switches and the first filter capacitor (100u), but only solder pads to connect them by wires.
                        The P1 dual pot, the input jack and fx-loop jacks are completely connected by shielded cables. Later I will attach photos.
                        • Tiny Terror Transformer - Overpowered?
                          Can anyone give me some thoughts on a power transformer for a Tiny Terror? I am building a clone and I think I just got one that may be overpowered. I picked up a Hammond 270DAX that has a 260 volt secondary. I bought this one after checking the output of a friend's Tiny Terror (that showed 252 volts on the High output). I just saw on this forum that they actual voltage off the secondary should be around 230 volts and that it would be better for this to be too low rather than too high.
                          So the question is - Would a 260 Volt transformer in fact be too high or is that considered within a reasonable tolerance? Would increasing the Cathode resistor do anything to offest this or would that open a whole can of worms down the power rail?
                          Thanks to anyone who has thoughts. And a general thanks to Thomeeque. We have all learned a ton from you and I for one appreciate it!
                          • Originally posted by Ivory Tower View Post
                            The specs say the max EL84 plate voltage is 300V +/- 10% but many manufacturers build amps with plate voltages of 340V or more, so I don't think you will have reliability problems.
                            The cathode res should be increased to increase the tube life, I put 150ohm.
                            You can find a detailed discussion on it at the beginning of this thread.
                            • Thanks Ciambom!
                              Does anyone have details on using a "dropping resistor" to reduce the voltage coming off a power transformer? I do want to try and drop the voltage from the 364 volts DC closer to the 325 that the design calls for (note I am talking about the "A" power rail, not the Plate voltage, per se). My (somewhat limited) understanding of dropping rsistors is that I could add one in series just after the output of the Rectifier bridge to get this voltage drop. I ran a quick and dirty analysis in Spice and it seems that a 10k (5W) resistor would drop the voltage just about right.
                              So the question: Is the process of adding a "dropping Resistor" as simple as this. Does anyone have this circuit modelled in spice? I'd love the file of that if anyone has one.
                              Any thought would be appreciated!Thanks,
                              Mike
                              • It sounds good!!
                                Finally I fixed my problem, the oscillation was due to a bad-designed pre-amp section on the PCB. The ground plane was a bad choice, it put a lot of noise on the pre-amp circuit. The noise was suppressed by wiring this part of the circuit.
                                Now it sounds good!!
