I have resolved this issue - MB
Peavey Classic 50/50 No output - tubes are not lit
Resolution
Hi, the resolution was something I have never run into before - it was actually
a bad fuse on the heater circuit - the strange thing was the fuse actually tested ok with an ohm meter but it was not working in the amplifier - I have never seen this before but when I put the fuse back into the holder and tested the the two point with a voltmeter set - it showed 6 volts - so I then did a bypass on the fuse the the tubes lit up. So ... I ventured out and bought a new ceramic 10A fuse and replaced the faulty unit.
Never seen a fuse show continuity but fail operations - but It is now working fine so I am happy and may have problems trusting a continuity fuse test again.
Thanks
MB
One thing - I found some of the existing threads on Peavey Classic encounters a great help - one actually was in the same fault isolation and the procedure actually led me through the voltage points (yellow to transformer) test points and this led me to the fuse susupect - thanks for the great site - excellent references for amp enthusiasts.
And on a closing note - while cleaning tubes and sockets I managed to get zapped off the main circuit board - ouch... seriously lit me up. Don't experiment with this - not worth the lesson. Unit was unplugged and I suppose it may be a worth while lesson to discharge the caps somehow before probing about.
Good thing I don't have a heart pacemaker.
Thanks all and Happy New Year... I lived again!
MB
Originally posted by innerservice View PostOne thing - I found some of the existing threads on Peavey Classic encounters a great help - one actually was in the same fault isolation and the procedure actually led me through the voltage points (yellow to transformer) test points and this led me to the fuse susupect - thanks for the great site - excellent references for amp enthusiasts.
MB
Originally posted by innerservice View Postit was actually a bad fuse on the heater circuit - the strange thing was the fuse actually tested ok with an ohm meter but it was not working in the amplifier - I have never seen this before but when I put the fuse back into the holder and tested the the two point with a voltmeter set - it showed 6 volts - so I then did a bypass on the fuse the the tubes lit up. So ... I ventured out and bought a new ceramic 10A fuse and replaced the faulty unit.
I used a soldered-in pigtail style fuse in the Workhorse amps for just this reason.
So maybe the thing to do is to trust a fuse continuity test, but trust it from pin to pin on the soldered ends of the fuse clip, not just the fuse itself.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
If you test the fuse while still in its clip, you are also measuring the very low resistance of the tube heaters and power transformer in parallel with it. That can look like a good fuse, when the fuse it self is actually open. ALWAYS pull the fuse from its clips to test.
Jazz, that silicone grease is meant to improve thermal conductivity, not electrical. You'd be better off wiping Deoxit on there.Education is what you're left with after you have forgotten what you have learned.
