Next term. What does "Computer Grade" mean?
"Computer Grade"?
Computer grade is used in reference to electrolytic capacitors.
It means a premium quality capacitor that was good enough to be used in the power supply of a computer, back when computers had linear power supplies and were expensive enough that manufacturers could afford to worry about build quality.
Of course now computers are made out of junk. Remember the epidemic of exploding capacitors on motherboards a few years back? "Inverter grade" is the new computer grade."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
Originally posted by Steve Conner View PostComputer grade is used in reference to electrolytic capacitors.
Built like a fine Swiss watch grade?
Truth in engineering grade?
Relentless pursuit of perfection grade?
These are merely suggestions.
To me, computer grade caps are rated at 105°C, with low ESR and able to work at high frequencies for use in SMPS. However, you can find caps like that which are pure garbage nonetheless, so the Madison Avenue moniker means squat.
Rather than listing to the hyperbole, the best defense against premature failure is to stick with known brands. It's not that THOSE are so wonderful either, but it makes it a bit less of a crapshoot.
Originally posted by Axtman View PostNext term. What does "Computer Grade" mean?
Originally posted by teemuk View PostThird one: "Audio Grade"Aleksander Niemand
Zagray! amp- PG review Aug 2011
Without the freedom to criticize, there is no true praise. -Pierre Beaumarchais, playwright (1732-1799)
to me it means one thing: BIG capacitance in BIG cans at BIG prices
Like the Evox Rifa PEH169 series!
example
PEH169MU547VM
47000uf 63VDC
78,000h lifespan at 85C
Ripple current: 29.6A at 85C/100Hz, 73.0A at 50C/10kHz
ESR: 0.005 Ohms at 100Hz 0.004 Ohms at 100kHz
inductance: 17nH
