Mod Parallel Effects Loop to be Serial?
  • Mod Parallel Effects Loop to be Serial?
    Is there a way to change my amp from a parallel effects loop to serial? Im pretty decent at soldering and just need some advice as to how much would need to change on the circuit.
    Thanks!
    Near as I can tell, that already IS a serial FX loop.
    No idea what model that refers to, but is there a FX mix control on the panel anywhere? That would be a sign of a parallel loop.
      Hmm. Interesting. Well, Its a Crate V32 Palomino Head. There is no effects mix knob like you said but i read on another forum that the way you tell if it is parallel is to plug a cable into the effects return jack and if you can still hear the guitar it is parallel. I have TC electronic gmajor effects systtem and all of the modulation effects sound like crap through this loop. So i assumed that it was a parallel.
